Re: forum etiquette
Posted by georgeky on February 13, 2007 at 10:33:58 from (152.163.100.199):
In Reply to: Re: forum etiquette posted by D Slater on February 13, 2007 at 10:16:00:
Hi, D Slater. I am glad someone else has seen this done. Just because you havent seen something does not mean it doesnt exist or cant be done. I seen a straight A with a Chevy starter and ring gear rigged up on the pto. You engaged the pto started the tractor then disengaged pto, it works like a charm. A friend of mine still uses that old tractor to plow tobacco with. It also has Chavy power steering pump for hydraulic lift.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
