Re: forum etiquette
Posted by D Slater on February 13, 2007 at 10:16:00 from (205.188.116.133):
In Reply to: Re: forum etiquette posted by gene bender on February 13, 2007 at 09:42:09:
There's M tractors around with brackets made to bolt to axle housing bolts,then the fast hitch with traction control is bolted to brackets. I have a set of myself. I'm sure a 350 style 2 point could be and probably is added to a H that same way somewhere.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
