Re: It's Hugh MacKay's fault
Posted by Hugh MacKay on December 17, 2006 at 17:35:22 from (216.208.58.110):
In Reply to: It's Hugh MacKay's fault posted by Lewis Smith on December 17, 2006 at 15:30:55:
Lewis: I'll accept the blame, but no more than 90%. The rest goes to the guy with the torch, welder, saw and wrenches. The platform carrier is a nice job. Do you have photos of your front blade, and the disk. I always like to see other peoples ideas.
Further to this, do your realize there is no cure until you have the complete set; A, SA, SA1, 100, 130 and 140. Once you have all 6 and 25-30 implements, you'll be cured. My diagnosis is, you have an offset infection or is that affection, whichever, you'll survive. Take care and collect fast hitch forks, you just never know when you'll need one.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
