Re: OT- Need help with farm truck
Posted by Bob M on November 21, 2006 at 15:07:51 from (69.205.115.200):
In Reply to: OT- Need help with farm truck posted by chadd on November 21, 2006 at 13:28:33:
Sounds like a bad key switch or starter button - whichever your truck has. If the key or starter switch is OK the "S" terminal on the solenoid will be at battery voltage when the key is turned to "start" or the starter button is pushed.
Try jumping between the hot (battery side) big post and the small "S" terminal at the solenoid . If the solenoid picks up and the engine cranks you've found the problem.
Note: The solenoid "I" terminal is not used on a diesel - there ordinarily is no wiring connected to it...
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
