Re: 300u Stuck after 1 week!!!
Posted by Janicholson on November 12, 2006 at 07:05:01 from (66.173.50.128):
In Reply to: Re: 300u Stuck after 1 week!!! posted by JayWalt on November 12, 2006 at 06:25:49:
The Drive on IH tractors starters are notorious for jambing into the ring gear. They can dammage the ring gear (requiring a split to fix) Sometimes they come loose by violent rocking of the tractor in high gear (with a loader, that is tough unless up) they always come loose by loosening the starter. A new drive is the ticket. When it is out, look at the ring gear to check its teeth compared to teeth just a little to one side. 4 cylinder 4stroke engines almost always stop in one of two places in the engine rotation due to compression resistance. If the teeth look fair, Leave it alone and get the newer drive from IH. JimN
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
