Re: Cub fuel issue
Posted by Louis Kocon Jr on November 09, 2006 at 06:52:06 from (204.111.110.153):
In Reply to: Cub fuel issue posted by Aaron65 on November 09, 2006 at 06:05:15:
Had a similar problem with a Cub I was restoring. (Hard starting and fuel leaking.) New wiring harness and a complete tune up took care of the hard starting. My gas leak was the result of warpage between the top of the carb and the lower bowl assembly. New gaskets did not help. If you held the carb up and looked at it from the side without the gasket installed, you could see the warp between the two parts. A new carb was the answer in my case. Good luck!
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
