Re: Water temp guage not reading
Posted by Bob on October 11, 2006 at 23:39:00 from (69.178.229.154):
In Reply to: Water temp guage not reading posted by albert460 on October 11, 2006 at 23:03:30:
Any time you pull a heat gauge bulb from it's intended location, and move it back out into a "tee", it's going to read lower.
Plus, you may be getting a flow of cooler water from low in the block, through the tank heater, and into the "tee" where the sender is.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
