Re: To buy a M or an H?
Posted by Dakotaclassiccycle on October 05, 2006 at 20:28:15 from (12.207.181.40):
In Reply to: To buy a M or an H? posted by Dakotaclassiccycle on October 05, 2006 at 20:17:26:
they arent to bad over here, but im not gona baja it either. i also was going to use it in the local tractor pulls ans such. would they run in the same class? if so i think the m would eat the h by the 100 foot mark.............
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
