Re: Farmall 400 fluctuaing voltages
Posted by Bob on September 03, 2006 at 23:35:18 from (66.163.134.211):
In Reply to: Farmall 400 fluctuaing voltages posted by JaredFarmall400 on September 03, 2006 at 20:03:43:
Simply toss your digital meter aside, and use an analog meter.
The electical "noise" produced by the ignition system is giving the meter you are using a "headache", and it's the meter that's coming up with the (false) weird voltages, NOT the tractor.
This is a common problem with using digital meters on these "electrically noisy" old machines.
Dig out an old analog meter, or pick up a new one for probably less than 20 bucks at WaldoWorld, that's plenty accurate for old tractor use, and your strange voltage "gremlins" from the confused digital meter will be gone.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
