Farmall 400 fluctuaing voltages
Posted by JaredFarmall400 on September 03, 2006 at 20:03:43 from (66.163.158.179):
Hey everyone, Went to hook a electronic tach up to my 400 today and it did not work. Following hours of testing I determined that for some reason when I run the tractor the voltage that comes through the system is very unpredictable. My multimeter goes from 2v to 160v's and it all over the place. However, it only does this when the tractor is running. When the tractor is stopped it reads a solid 12.6 volts. I have always had a problem getting this tractor to charge the battery properly, always seemed like the battery was going dead. Thought the voltage problem was releated to the gen. So I unhooked the voltage regulator and the gen belt with the same results. I even tried hooking up a seperate battery to the ignition. The ignition battery showed fluctuatingvoltages and the rest of the sytem showed good. Not sure what is causing this problem, but I can't get the tach to work and I am thinking this is causing the gen to not function properly. The battery is hooked up positive ground and the tractor was converted to 12 volts at one time. Do I maybe need to reverse the polarity to negative ground? Not sure what to do. Any comments appreciated. Thanks
Home
| Forums
| Order Support
Today's Featured Article -
Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
Latest Ad:
65 Massey FERGUSON DIESEL
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
