Re: Super A magneto...DOA
Posted by Brownie 45 on August 05, 2006 at 14:06:25 from (207.177.82.221):
In Reply to: Super A magneto...DOA posted by Jd lost in VA on August 05, 2006 at 13:00:55:
As long as you have it this far down, hold a finger on the top contact on the coil, & turn the engine over. See if a spark is weak or rather strong at the coil terminal. If a weak spark is available, the points & cond are likely needing attention. If a strong spark is at the coil terminal, look for problems in the coil cover or distributor cap, or rotor or high tension wires.
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
