Super A magneto...DOA
Jd lost in VA
08-05-2006 13:00:55
third party image
On the advice of members of this forum, I Removed the kill wire from the side of the mag/dist.
removed the center wire, held it close to ground, but I get zero spark.
This is where it is now.
What do I do next?
(It was not sitting for years and years, only a few.)
shoo_giesty
08-06-2006 03:53:56
 Re: Super A magneto...DOA in reply to Jd lost in VA, 08-05-2006 13:00:55
if i was you i would send it to magman. he did one for me and did an excellent job and it isn"t really that expensive to have it done.
Jd lost in VA
08-06-2006 07:44:32
 Re: Super A magneto...DOA in reply to shoo_giesty, 08-06-2006 03:53:56
If all else fails, I might talk to the Mrs. about funds and do just that.
I would feel a lot better if I could get the mag working on my own. I like to learn new things and be able to fix the entire machine on my own.
magman
08-05-2006 14:50:53
If you got the bucks I will fix you up.If you dont feel comfratable doing it your self you can send it to me and I will fix you right up in a couple days.She will work, And shine like a bald mans head. JON
Jd lost in VA
08-05-2006 16:00:56
 Re: Super A magneto...DOA in reply to magman, 08-05-2006 14:50:53
That would be nice, but I don't have the bucks.
I am a poor poor man.
Brownie 45
08-05-2006 14:06:25
As long as you have it this far down, hold a finger on the top contact on the coil, & turn the engine over. See if a spark is weak or rather strong at the coil terminal. If a weak spark is available, the points & cond are likely needing attention. If a strong spark is at the coil terminal, look for problems in the coil cover or distributor cap, or rotor or high tension wires.
Bob
08-05-2006 13:41:17
Start by cleaning and gapping the points.
Here's a link to the IH Blue Ribbon mag service manual on the Cub Collectors site:
Link
(As always, with this link, you'll have to cut and paste it into your browser's address box.0
Jd lost in VA
08-05-2006 13:06:07
third party image
And for someone who asked about my planter attachemtn, this is it.
