Re: Hydraulics lost
Posted by Janicholson on July 19, 2006 at 12:39:20 from (199.17.6.122):
In Reply to: Hydraulics lost posted by hbauer on July 19, 2006 at 11:33:29:
If the drive coupling to the pump is disconnected ot broken, the pump does not turn. It is easy to look at through the sheet metal cover to the rear of the pump on the bottom of the tractor. There should be no oil in that location to dump on you. As noted, the pump is not live. the clutch must be let out for operation. Good luck, JimN
