Re: 240 wiring
Posted by John T on July 02, 2006 at 18:38:43 from (66.244.90.5):
In Reply to: 240 wiring posted by Rob in Ore on July 02, 2006 at 12:45:52:
Rob, if the ammeter is wired correct if you turn on the lights or ignition (unless its a mag) when shes not running it ought to swing over to - discharge, but then once running if shes charging swing over to + charge. If it does just the opposite of that swap its leads side to side and it will then register correctly. Normally theres but ONE wire on the ammeters SUPPLY terminal which is to the battery/starter often at the starter switch or solenoid where the big battery cable attaches. Its other LOAD terminal is what feeds loads like lights n ignition (unless its a 4 pole VR with the L terminal) PLUS wires to the BAT terminal on a Voltage Regulator/Cutout Relay. If you wired up a VR in opposite polarity it could harm it so to be safe be sure n re polarize the genny once all is rewired. If a bunch of wires are bad or frayed I like your idea to re wire the whole thing n be done with it. John T
Home
| Forums
| Order Support
Today's Featured Article -
Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
Latest Ad:
65 Massey FERGUSON DIESEL
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
