Re: H Governor problem?
Posted by Wayne Swenson on June 05, 2006 at 08:05:44 from (66.228.250.33):
In Reply to: H Governor problem? posted by Leon W on June 05, 2006 at 06:12:38:
When synchronizing carburetor & governor, first loosen the 2 screws on the tube that attaches the carburetor to the governor housing. Be sure the carburetor end is tight then gently tap on the tube to "center" it; tighten the screws on the governor end. Now remove the breather tube cover (angled surface) and with the throttle lever wide open, check that the linkage pin is easily inserted into the clevis while holding the throttle operating rod wide open (rotate upward on the rod). Run the engine to warm and re-adjust the mixtures for high & low speed operation. At WOT turn the bottom screw in & out to achieve maximum RPM"s (near perfect combustion, not best for puling); then add 1/2 turn out or more for power as the need dictates. At idle, repeat the process but note that the idle screw is adjusting air flow, not fuel, so turning in richens the mixture. Reset idle speed and repeat the process to assure accuracy. I enjoy working with carburetion; just don"t like old gas (10-20 years old) in the carb when trying to rebuild them. Phew!!
Home
| Forums
| Order Support
Today's Featured Article -
Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
