Re: 656 carburetor
Posted by RustyFarmall on May 26, 2006 at 06:51:16 from (207.32.13.222):
In Reply to: Re: 656 carburetor posted by Don, Ohio on May 26, 2006 at 05:46:29:
The kit came from Case-IH so you got the best kit there is, and the needle most likely is the viton tipped needle valve, which is just about all you can get anymore. The viton tipped needle valves do not usually cause any trouble, but occasionally they do give trouble, so you might want to doulble check it, and while you are in there double check your float setting. I think that carb uses a double float, so you want to make certain that both sides of the float are set exactly the same, and also make absolutely certain that both floats do not rub or hang up on the fuel bowl. The float can be manipulated so that it clears everything.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
