Re: 656 carburetor
Posted by Don, Ohio on May 26, 2006 at 05:46:29 from (71.72.140.9):
In Reply to: Re: 656 carburetor posted by Brownie 45 on May 26, 2006 at 03:23:24:
I installed a new gasket with the new seat and it is tight. I don't think the casting is cracked. I purchased the overhaul kit from the local Case-IH dealer, so the needle is whatever they supply -- I don't know whether it is viton or standard. I also installed a new float since that came with the kit.
Don
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
