Re: Lottsburg, VA
Posted by El Toro on May 14, 2006 at 04:33:41 from (205.188.116.133):
In Reply to: Lottsburg, VA posted by Bud Nolan on May 13, 2006 at 19:17:33:
You may not be connected to the correct terminal on your ignition switch or if it is the switch is probably defective. There should only be voltage
present on that terminal when the switch is in the on or run position. You are still feeding voltage to the coil when it keeps on running with the switch in the off position. Check that terminal with a volt meter when switch is off. Hal
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
