Re: farmall H still not running
Posted by captaink on April 18, 2006 at 05:55:05 from (66.115.214.56):
In Reply to: farmall H still not running posted by jdo on April 17, 2006 at 16:06:12:
You have a plug in the fuel supply to the carburetor. Turn the fuel off under the tank. Then start by taking the fuel line off the carburetor. When you turn the fuel back on you should gave a very good stream running out of the line. If you do then check for a screen screwed into the inlet of the carburetor and see if it is plugged. If you just have a drip, take the line off the sediment bowl. Again you should have a steady stream. If you do, then replace the rubber fuel line. (Rubber lines will work, but over time can deteriorate and the rubber collapse and close off the line.) If you still only get a drip, then take the glass (or possibly metal) sediment bowl off and clean it and the screen on top of the bowl (between the gasket and the sediment bowl metal). While you have the bowl off, turn the fuel on and see if you have fuel coming out of the tank. If not, either take the tank off and tip it so that you can take the sediment bowl out without loosing fuel, or take an air compressor and blow air back into the tank though these holes. The next time the tank is close to empty, take it off and clean it out or this will happen again. Once you have good fuel flow to the carburetor, the H will run.
Home
| Forums
| Order Support
Today's Featured Article -
Upgrading an Oliver Super 55 Electrical System - by Dennis Hawkins. My old Oliver Super 55 has been just sitting and rusting for several years now. I really hate to see a good tractor being treated that way, but not being able to start it without a 30 minute point filing ritual every time contributed to its demise. If it would just start when I turn the key, then I would use it more often. In addition to a bad case of old age, most of the tractor's original electrical system was simply too unreliable to keep. The main focus of this page is to show how I upgr
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
