Re: Hercules overheating
Posted by Chuck on January 02, 2006 at 16:23:11 from (24.128.133.34):
In Reply to: Hercules overheating posted by chuck on January 02, 2006 at 12:20:19:
There is a drain located on the cast elbow at the bottom of the pump. This comes from the bottom Rad. hose. Coolant flys out of there when the drain is opened. The radiator seems to flow pretty well. I can't understand how the pump can obviously be pushing water thru that heater hose but not up thru the block and head and into the top of the radiator. The radiator stays stone cold top and bottom. I may try removing the thermostat but I've never seen a bad one out of the box besides it was doing the same thing with the old one which tested good. You can tell there is no water flow because once it gets hot and you shut it off for a while it will heat back up in a minute once running again. I know the oil system carries away alot of the engine heat so I was concerned with poor oil flow but if it was an oiling problem the radiator should still be getting hot and showing some flow. I don't know for sure exactly how hot it is getting but it's uncomfortable to the touch and any grease deposits on the engine start to burn off.
Home
| Forums
| Order Support
Today's Featured Article -
Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted
... [Read Article]
Latest Ad:
65 Massey FERGUSON DIESEL
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
