Re: Clutch adjustment
Posted by Hugh MacKay on November 19, 2005 at 13:31:57 from (209.226.247.179):
In Reply to: Clutch adjustment posted by Clutch problems on November 19, 2005 at 11:33:01:
Does this Farmall 400 have TA either working or non-working TA. If so you must adjust both clutch and TA in sequence even though TA may not be working. Get a manual and adjust by the book and precisely to the letter. Close does not count even a little bit with these.
Post a Followup
