Clutch adjustment
Posted by Clutch problems on November 19, 2005 at 11:33:01 from (152.163.101.13):
I have a 400 Farmall that the clutch is not releasing good and need more adjustment. I have the linkage between the pedal and the clutch arm adjusted with almost all the free travel out and you still have trouble getting it into gear. The pressure plate fingers have adjustments on them near the pivot point (not where the touch the throw out bearing). Would adjusting the fingers change the geometry and make the pressure plate release the clutch plate any more? I just bought this tractor and do not know the history.
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
