Re: Fan Belt Installation for IH H Tractor
Posted by john d on September 03, 2005 at 22:03:52 from (69.128.200.18):
In Reply to: Fan Belt Installation for IH H Tractor posted by Robert in DW on September 03, 2005 at 19:21:58:
The adjustment is by means of a threaded sheave on one side of the pulley located on the fan hub. Look closely at that pulley, and you'll see threads on the front portion of the hub. You'll also find a set screw with a locking nut on it. Loosen the nut, then remove the set screw. Actually you don't have to totally remove it, but....it may have been 20-30 years since that pulley's been adjusted. My advice is to remove it totally. Spray some good penetrating oil into the hole where the set screw had been, and turn it up on top so the oil can start working on the threads. If you have a wire brush, clean the threads in front of the pulley. If you don't have a wire brush, use an old toothbrush and some carb cleaner or more penetrating oil. When the threads look pretty clean, use a long punch and a hammer to TAP on the raised boss opposite where you removed the set screw. Tap it one way for a while, then the other way, until it starts to turn. (Note: do NOT CLOBBER THAT HUB AND BREAK IT!) Patience is required in this adventure! Once the hub has been cleaned and loosened until it will turn freely on those threads by hand, you're ready to put on a new belt, tighten the hub, and re-install the set screw. Don't forget the lock nut! The end of the set screw is supposed to go into the groove machined into the threaded portion. I replaced the one my '49 M a couple of years ago, and it took me well over an hour to get it all cleaned, loose, and put back together. It's amazing how much dirt can lodge in those threads! The belt does not have to be extremely tight to work well. A similar system is used to tighten the generator belt, with the movable pulley sheave being on the generator.
Home
| Forums
Today's Featured Article -
Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
