Lift-All correct operation
Posted by haymeadow52 on August 02, 2005 at 19:37:00 from (12.26.62.76):
Farmall H Lift-All: Someone please straighten me out here. When I pull back on the lever so the little bump on the rod is just rear of the bracket, should the cylinder already be lifting? Or is that position supposed to be a "resting" position? (not raising, but not lowering either). I do have the manual for the Lift-All, but I only see reference to "pulling all the way back on the rod momentarilly, then let go" and that should continue lifting the cylinder until the end of its travel, then it releases back so the bump is just behind the bracket. ...and what do i need to do to fix mine? thanks.
Post a Followup
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
