Re: clacking sound / burned glow plugs
Posted by P Backus on July 02, 2005 at 07:02:59 from (69.128.32.13):
In Reply to: clacking sound / burned glow plugs posted by BABOS on July 01, 2005 at 16:48:34:
Ouch, that doesn't sound good!
Are you sure that the rod cap is torqued up properly? Did you
change out the timing gears? I've heard them clack. It could be
in the valve train- if so it would clack at one half of engine speed
(700 clacks per min. at 1400 engine rpm). Wrist pin? Just
thinking aloud here. What was all done in the rebuild? All new
bearings? I once had an oil pump driven gear crack and started
to clack after a rebuild.
I don't know about the glow plugs. Are you sure that the switch
isn't sticking and keeping them on too long? What tractor is this
in? More info would be helpful- keep us posted.
Paul
Post a Followup
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
