Re: clacking sound / burned glow plugs
Posted by jossette on July 02, 2005 at 06:47:04 from (216.114.223.193):
In Reply to: Re: clacking sound / burned glow plugs posted by Babos on July 02, 2005 at 04:20:24:
what are you working on
ih
cat
cummins
detroit
johndeere
soinds like a valve spring dropped or the injector is not opening up or that line is plugged, or the lines are rubbing together and there is pin hole letting in air...while running with a slight crackling noise--- crack the line at the pump to see if fuel comes out. crack the line at the injector to see if fuel is there. somewhere it needs to get fuel..
worse case?? scored cyclinder
Post a Followup
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
