Re: 350 utility steering
Posted by jk on May 12, 2005 at 15:28:16 from (64.112.198.238):
In Reply to: 350 utility steering posted by jk on May 09, 2005 at 16:23:46:
i red the procedure in the I&T book. how much slop or play should there be at the steering wheel before anything moves? i replaced the starter last month and when i took off the tie rod it was loose. the other side was loose on the splines too but that didn't help anything. last week end i helped by buddy pull the motor, transmission and transfer case out of his S-10 pickup. the front end was alittle light, even with the snow plow frame on it, but it picked it up with out any problem. its mostly a strong tractor, i've picked up a complete F-12 transmission, rear end with it. the steering donesn't bother me that bad, just as long as its safe to move in road gear. but it would be nice to remove some of the slop if i could. thanks
jk
Post a Followup
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
