Re: 6 volt starter with 12 volt system
Posted by lee on January 17, 2005 at 10:19:49 from (24.24.95.246):
In Reply to: 6 volt starter with 12 volt system posted by Darin S. on January 17, 2005 at 09:54:44:
from long ago you may have learned: volts = amps x resistance or, rearranging things to better fit our purpose amps = volts / resistance regardless of what the resistance is (starter resistance is very small by the way) the resistance hasn't changed because, uh, you haven't changed the starter right? The volts are doubled like this (6 x 2 = 12) so the formula simply says the amps are doubled. Most notably, all this means is it'll spin like never before and burn up rather quickly if you grind and grind and it doesn't start. If it doesn't start right off, fix the problem. The starter will last a good long while assuming it is in good shape and you don't abuse it. The doubled amps are harder on brushes and commutator and they build heat in the armature and field coils more quickly.
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
