Re: 6 volt starter with 12 volt system
Posted by lee on January 17, 2005 at 11:47:36 from (24.24.95.246):
In Reply to: Re: 6 volt starter with 12 volt system posted by Andy Martin on January 17, 2005 at 10:44:47:
I tried to keep it simple. It is actually more complicated as you suggest. The starter is as you say a motor, so the current will vary with load. The cranking load is the same at any given cranking RPM no matter what battery is used. And it makes sense to assume that the load would increase with increased cranking RPM. You have to work harder to crank faster. I did not elaborate on my earlier post that what I stated only applied to a special case, a locked armature condition. Only at the very instant electrical contact is first made (the armature stationary) will the amps be double. It's called locked rotor current. A better way to look at the whole mess might be to look at the electrical power applied to the starter. here goes. For electrical power in WATTS WATTS = AMPS x AMPS x RESISTANCE or for the same thing another way WATTS = AMPS x VOLTS Since I don't have actual numbers I'll just use words and say that the power applied to a 6 volt starter with a 6 volt battery is much less than that applied to the same starter by a 12 volt battery. If it were not the starter could not crank the engine faster as we all know it does with a 12 volt battery. The Volts we know have doubled from 6 to 12. The AMPS may even be less (than for the 6 volt case) as you say (I'm not sure) but they are certainly not near half so the power delivered in watts is much greater for the 12 volt case. It's the power that heats up the starter and can cause it to burn up more quickly. I'll stop here.
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
