Farmall Tractors Discussion Board
Re: Re: Re: Cracked wheel
Posted by Bob M on November 20, 1999 at 07:32:00 from (152.163.204.192):
In Reply to: Re: Re: Cracked wheel posted by Wisconsin Ron on November 19, 1999 at 20:51:11:
Same thing happened to me, only it was an outside dual wheel. Clamp bolts worked loose, the wheel flopped on the axle a couple times and broke out a chunk of the hub. Bolted it back up tight and the wheel is still working 20+ years later...
Post a Followup
: Re: Re: Re: Re: Cracked wheel
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
