Re: Farmall 400 vs 450
Posted by DWV on September 21, 2004 at 10:41:09 from (64.12.117.22):
In Reply to: Farmall 400 vs 450 posted by LarryM on September 21, 2004 at 06:41:55:
About the engine you have answered your own question. If it has 264 on block its a 400 or 450
with 400 engine.Not enough differance in engines to worry much about.Most 264 have been changed over years to 281,also most gasoline used same
clinder head.Later 400 went to smaller wrist pin
which carried through 450.450 changed to left hand thread camshaft gear nut after early ones.
Early 400 cast # on block ended in R1,later 400
and 450 ended R2.On missing serial #,is it missing
on engine or tractor?If engine may be replacement block.
Post a Followup
Subject:
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
