Re: help with M radiator/steering shaft!!
Posted by CNKS on March 19, 2004 at 13:11:25 from (207.178.96.211):
In Reply to: help with M radiator/steering shaft!! posted by rick in Sioux Falls SD on March 19, 2004 at 12:29:32:
Take the horizontal part loose in front of the U-joint, it's held by a clamp, woodruff key and bolt. The shaft will then unscrew from the sector gear and will pull right out. Replace the seal on the rear top of behind the sector gear or it will leak when you reassemble. Mine leaked anyway, so I repacked the gears with grease.
Post a Followup
: Re: Re: help with M radiator/steering shaft!!
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
