Re: 6 or 12 volt??
Posted by BIG JOHN on December 13, 2003 at 17:38:16 from (205.188.209.82):
In Reply to: 6 or 12 volt?? posted by Farmallkid on December 13, 2003 at 16:07:05:
I always go to 12 volt system if the generator or the regulator need work. If they are working properlly then put on new 2/0 battery cables. You will probably have to make them. Welding Supply houses all have the cable and Auto Parts houses will have the ends. In addition to the new cables I always run the ground cable to the base of the starter. There is no substitute for these heavy duty cables on a 6 volt system.
Even if you change to a 12 volt system later the cables will never be a wasted expense.
I am like you a 6 volt system never really works well for me, so it really doesn't take much for me to change to 12 volts.
GOOD LUCK
Post A Followup
: Re: Re: 6 or 12 volt??
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
