Re: Re: grease fitting on front hubs
Posted by Hugh MacKay on September 12, 2003 at 17:28:46 from (209.226.247.34):
In Reply to: Re: grease fitting on front hubs posted by Bill Smith on September 12, 2003 at 11:52:45:
Bill: I will agree with you on the wheel bearing grease. However if you grease right, with factory installed zerks, no problem. I can tell you front hubs were never off my 656 in 13,000 hours They were off my 1066 in 11,000 hours but not for greasing, broken spindles was the reason. Both those tractors went the time with original bearings and seals
Post A Followup
: Re: Re: Re: grease fitting on front hubs
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
