Re: grease fitting on front hubs
Posted by Bill Smith on September 12, 2003 at 11:52:45 from (63.147.130.16):
In Reply to: grease fitting on front hubs posted by SCOTT IN MO on September 11, 2003 at 17:27:36:
I agree with all that has been said. Especially the statement's about using wheel bearing grease and not multi-purpose, and the one about doing a good job packing the wheel bearing. When packing a wheel bearing, make sure the bearing gets full of grease in-between all the rollers. You can do this simply by putting grease on the palm of your hand, and with bearing in the other hand smash the grease right into the bearing. Its messy, but you can get it full of grease this way if you don't have one of those fancy bearing greasing deals. Also when packing bearings, I always clean the inside of the hub real good and fill the inside cavity of the hub full of wheel bearing grease. If you don't, the grease will work its way out of the bearing and into this area where it won't do the bearing any good. If this area is full of grease, the grease in the bearing can't work its way out into this area because its allready full. You will probably use up the entire can of grease doing this, but hay grease is cheap and no reason not to do it. Greasing by way of zerk in dust cap isn't going to be near as good as doing a bearing packing job. Even if using the zerk, I would still plan on doing a packing job ever so many operating hours. Maybe more hours than if not using the zerk.
Home
| Forums
Today's Featured Article -
The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
