Re: Re: Inner wheel bearing on an H - What a Job!
Posted by WIRED on September 07, 2003 at 08:52:18 from (169.207.132.85):
In Reply to: Re: Inner wheel bearing on an H - What a Job! posted by Kelly C on September 06, 2003 at 20:37:29:
I used about $4.00 worth of cut-off wheels on my Dremel tool to cut the race. The nice thing about those is the size -- about 2" in diameter, so you can get in small spaces and control the cut. If you don't twist them, they cut well and don't break. Good luck to you. I fully understand and appreciate your situation. The only thing left on my "to do" list is to replace 4th and 5th gear, as they appear worn, and now is the time to do it. So out comes the differential, and that will give me the chance to replace the brake housing seals at the same time. Then, the great rebuilding project starts, and I'll be twisting bolts for a month of Sundays.
Home
| Forums
| Order Support
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
