Re: Inner wheel bearing on an H - What a Job!
Posted by Kelly C on September 06, 2003 at 20:37:29 from (63.171.43.140):
In Reply to: Inner wheel bearing on an H - What a Job! posted by WIRED on September 06, 2003 at 13:22:13:
There are some butt kicking bearings on a H.
I am trying to replace the clutch pilot bearing on my H.
Broke the arms on my bearing puller.
Pounded on it off and on for 2 days with no luck. Trying to bust it up and take it out in peices.
Today I did get the inner race out. I took my stick welder and turned up the voltage and burnt it out. Then the balls came out.
Outer race is stuck like it is part of the fly wheel.
I tried the welder trick again. Figured I could run a bead inside the outer race and shrink it to remove.
Nope, all I did was weld the outer race to the fly wheel.... ARG!!
SO off to the hardware store to get a die grinder.
Its coming out of there one way or the other. I will try grinding it in half to get it out. Then of course fix the welding thing :-)
Post A Followup
: Re: Re: Inner wheel bearing on an H - What a Job!
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
