Re: Farmall M PTO Adjustment
Posted by 49 Cubber! on July 17, 2003 at 19:24:31 from (206.74.216.18):
In Reply to: Farmall M PTO Adjustment posted by MEGdairyfarm on July 17, 2003 at 17:01:59:
When you pull the pto unit out,check to see if the thin metal spacers are still in there between the pto unit and the tranny housing.Take those out and you can buy some time like that.Check the ends of the pto shaft and the shaft in the tranny and if youre lucky,you can get by with repalcing the shaft.
Post A Followup
: Re: Re: Farmall M PTO Adjustment
Today's Featured Article - Tractor of the Month - by Staff. decals, dependin upon the configuration of the parent company International Harvester in the year of production. For the purpose of this article, we will refer to the tractor as simply a "Farmall Cub". This little tractor was aimed at the needs of the small-acreage farmer - farms of 40 crop acres or less and truck gardens, or for larger farms that needed an extra tractor. Seven or eight implements were initially designed for it: Plow, Disc, Backblade, Sickle-Bar ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
