Re: F-20 Compression
Posted by Bill Smith on June 06, 2003 at 12:00:08 from (63.147.130.86):
In Reply to: F-20 Compression posted by Pete LaBelle on June 06, 2003 at 10:29:31:
That sounds a little low to me. I would guess it should be more than that. If nothing else, the 15 psi difference on the one intells a problem. Since this tractor is without electrical start (more than likely) the test moreless has to be done by handcranking. Just try to crank consistant with the same speed and forse for the entire test on all 4 cylinders. The faster you spin it the better since that will be closer to normal running speed than cranking slower. The slower you crank the more compression will be lost because it gives it more time to leak out. But you can still only go so fast and the faster you go probably the less consistant you are going to be with the force and speed of the cranking. You might try taking several readings on each cylinder both dry and wet. If no change from dry to wet, the problem is valves or seats or head gasket. If there is a change from dry to wet then the problem is likely piston to sleeve clearance or rings. If you are coming up with different readings on just the dry, or just the wet on one cylinder, then you might want to average the readings on that cylinder when you are comparing one cylinder to another.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
