Re: Re: 1456 burning oil
Posted by IH4EVER on July 15, 2002 at 10:19:35 from (205.188.200.59):
In Reply to: Re: 1456 burning oil posted by ca on July 15, 2002 at 09:01:35:
Tractor does not have slober at the manifold gaskets or out the straight pipe, But we are going to pull the head this winter and check it out. Thanks for the help ca
Post A Followup
: Re: Re: Re: 1456 burning oil
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
