Re: 1456 burning oil
Posted by ca on July 15, 2002 at 09:01:35 from (207.54.105.157):
In Reply to: 1456 burning oil posted by IH 4 EVER on July 14, 2002 at 19:25:42:
Its what's called exhaust slober from idling. Oil seeping down the valve stem when the engine is only at an idle or lower rev's. We see it on some of or tractor when there cold untill they warm up. Also some of them like the german D310's And D358's have a litte blue smoke when there doing the litte idle work but this clears up when there but on a normal work load.
I think there are valve spreders or what they call sheeders that throw the oil away from the valve stem to slow this down. On some engines this is an update. Even the IH D414 -DT466 drip oil from the exhaust manifolds if they do alot of ideling for extented periods.
Some oil down the valve stems is required. But if its getting bad. You may need to redo your head with new valve and guides. New valve springs if you go that far and see if theres an update to newer retainer ,Spreeder, Sheeder Not sure of the name right now. That help with this proplem.
Good Luck
Post A Followup
: Re: Re: 1456 burning oil
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
