Re: Re: International 574 D239 Oil Breather Problem
Posted by Diesel Bob on May 19, 2002 at 13:23:15 from (213.1.68.191):
In Reply to: Re: International 574 D239 Oil Breather Problem posted by IH Neal on May 17, 2002 at 03:54:12:
Overhere in England we had a similair problem when the tractor was ploughing and the one set of wheels were in furrow this was easily cured by a modification that was from IH at the time it is no longer available but somthing very similair is fitted to the newer models all you do is blank of the breather on the camshaft inspection plate and purchase a new rockerbox cover with breather and filter built into it
We also had a problem with oil leaking out of the breather after a engine rebuld and it turned out that we had fitted tapered top rings to the 1st ring groove instead of the standard square ring this was fixed when we fitted the correct piston rings hope i have been of some assistance
Post A Followup
: Re: Re: Re: International 574 D239 Oil Breather Problem
