Farmall Tractors Discussion Board
Re: counter shaft, pinion gear replacement on a Super A
Posted by Curt Cooke on August 04, 1999 at 07:16:10 from (207.75.224.250):
In Reply to: counter shaft, pinion gear replacement on a Super A posted by bronco on August 02, 1999 at 19:54:40:
No.
Post a Followup
: Re: Re: counter shaft, pinion gear replacement on a Super A
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
