Re: HM cotton picker.
Posted by NDS on June 17, 2007 at 09:56:49 from (152.163.100.197):
In Reply to: HM cotton picker. posted by georgeky on June 16, 2007 at 23:21:06:
If tractor was indeed cotton picker tractor it was a low drum picker or axle housings have been changed, high drum axle housing have flange on ends to bolt on drop housings, low drums were not high clearance. Low drum pickers were reversed internaly by flipping ring gear high drums were reversed in drop axles. If gear shifter is in normal position it will go foward in 1 thru 5 gears if frame cover has dual shifter positions and shifter is on opposite side from normal tractor it will travel backward in gears 1 thru 5.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
