Re: 1066
Posted by dhermesc on May 01, 2007 at 07:16:39 from (24.248.193.103):
In Reply to: 1066 posted by pete_5959 on April 30, 2007 at 17:46:35:
Condition is well over 70% of the price. I've seen running 1066s go for $3500 and good 1066s in the $9000 range (auction prices). That being said a brush hog tears the **** out of any tractor - especially if it a larger bat wing model.
As mentioned below a 1066 is a pretty big tractor for baling square bales. If you backed up to a 806-886 size tractor - especially with a German deisel - you gain a lot of efficiency.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
