Re: 1066 Hyd Clutch-Hey Owen AaLand
Posted by Owen Aaland on April 04, 2007 at 19:22:29 from (65.165.246.155):
In Reply to: 1066 Hyd Clutch-Hey Owen AaLand posted by Michael Sheik on April 04, 2007 at 19:02:41:
The leak you are looking at is the seal on the TA pressure dump valve. Once you get the linkage off of the stem, just unscrew the nut and the valve assembly will slide out. There is an o-ring that seals the threaded side of the nut and a lip style seal pressed into ther other end of the nut where the stem slides through. Be sure to wash the area off before you start so you get dirt into the MCV assembly. I usually use brake cleaner for these small areas.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
