Re: 3588 PARK and pawl
Posted by JJK on March 17, 2009 at 17:15:18 from (166.216.128.13):
In Reply to: 3588 PARK and pawl posted by kidd1954 on March 17, 2009 at 05:20:41:
As long as the linkage isn't bent or wore the other thing I'd check is if that triangle overcenter piece is on the right way. Out is molded into one side of this part. Make sure that faces away from the trans.
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
