3588 PARK and pawl
Posted by kidd1954 on March 17, 2009 at 05:20:41 from (67.68.55.92):
I have a 3588 on the flat the park engages fine but with any sort of resistance against it (Like on a hill) the pawl will not hold it just sounds like a rachet (pawl in and out of teeth). I have the top plate off and the gear looks good no missing teeth and the pawl looks a little rounded at the bottom point but notheing major. Is it just a linkage problem? I tried to ajust the linkage so the pawl shaft would go as low as it could into the housing but when I did that the over center piece didn't come back far enough when I took the park lever out of park to neutral.
I hope this makes some sort of sence to someone. HELP
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
