Re: Single Pole Alternator
Posted by Werf on December 25, 2001 at 17:36:12 from (66.181.130.57):
In Reply to: Single Pole Alternator posted by Marlin Mangels on December 24, 2001 at 04:44:11:
I had the same problem once. I ran two extra wires to the voltage reg terminals and hooked up a push button. When you push the button it excites the regulator and starts to charge. It has worked trouble free for two years. The tractor is a club tractor and has multiple operators, so some don't like to rev up all the way. That is the real secret, rev up ALL the way. don't be afraid to let the engine warm up for awhile before revving it up, running the engine takes very little power. I have found that the one wire is very reliable. Just my thoughts and input. Good Luck
Post A Followup
: Re: Re: Single Pole Alternator
Today's Featured Article - Tractor of the Month - by Staff. decals, dependin upon the configuration of the parent company International Harvester in the year of production. For the purpose of this article, we will refer to the tractor as simply a "Farmall Cub". This little tractor was aimed at the needs of the small-acreage farmer - farms of 40 crop acres or less and truck gardens, or for larger farms that needed an extra tractor. Seven or eight implements were initially designed for it: Plow, Disc, Backblade, Sickle-Bar ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
