Re: 2 point hitch
Posted by crockofbc on December 20, 2001 at 05:36:49 from (192.249.47.9):
In Reply to: 2 point hitch posted by Steve on December 19, 2001 at 19:59:06:
Super C thru 240 is 2-1/2" high
300 & up is 3" high
Equip like mowers always had the small prongs. IH made an adapter plate to use on larger tractors. It's really simple to make. All you need is a couple pieces of 1/2" thick bar stock narrow enough to fit in the sockets. I believe there are also holes in those sockets so you can pin the adapter in so it doesn't fall out when you take off the implement.
Post A Followup
: Re: Re: 2 point hitch
